HELP NEEDED IN HEMEL! No brakes! PLEASE ADVISE
    Originally posted by TonyN
    Check the other side as well, or just replace them both with longer pipe to make up for the lift the truck has.
    Just a thought as this truck has been lifted would it be an idea for any one who has a lifted truck to check their brake pipes for any stress?. Just for safety sake!
      Not many people have that much of a spacer, I usually put just a 1" spacer under the t-piece to relieve strain on the flexible pipe when doing a 2" lift, ideally you should replace the flexible hose with a longer one, especially when doing a 4" lift and leave the rigid line clipped close to the axle to save them getting snagged when offroading.
      The fronts normally have 2 or 3 big loops you can straighten out.
        i have always used ed`s treads near halfords,they did the pug`s break lines
