I have 265x70x15 on my 2.4 and am thinking of changing to 31x10.5x15 what are the benefits/drawbacks to changing...anyone done this and can you point me in the right direction...Cheers...
265x70x15 or 31x10.5x15??
Cheers..just confused there!!! but i cant see 1" making any difference..think its the 31" then...Originally posted by TonyN265/70 are about 30x10.5" 31's are...well 31"
So about 1" different in dia is the difference.
[U]SORRY OFFICER...I HAVE BEEN IN ALL EVENING...[/U]
31s it should be, they fit without a lift, fill out the arches a bit better and more importantly give you 1 inch extra ground clearance and therfore better approach, departure and breakover angles.Originally posted by TRUCKMANCheers..just confused there!!! but i cant see 1" making any difference..think its the 31" then...
And if you go for the General Grabber from roughtrx I can recommed as I fitted a set last weekOriginally posted by TRUCKMANI have 265x70x15 on my 2.4 and am thinking of changing to 31x10.5x15 what are the benefits/drawbacks to changing...anyone done this and can you point me in the right direction...Cheers...
£56 each brill
Brian
1/2" at the top and 1/2" at the bottom of the tyre .Originally posted by lucky31s it should be, they fit without a lift, fill out the arches a bit better and more importantly give you 1 inch extra ground clearance and therfore better approach, departure and breakover angles.
I think you will find particularly on Mud Terrain tyres that the chunky tread depth is actually additional to the specified tyre diameter. So go for an agressive tyre with 25mm deep tread and they're much bigger! Until they wear down- then you're back down to a mere 31" !Originally posted by fatfiresTill they wear!!!
_________________
Nevillef
Here's a set of General Grabber MT's 31x10.5x15 on E-Bay:Originally posted by TRUCKMANI have 265x70x15 on my 2.4 and am thinking of changing to 31x10.5x15 what are the benefits/drawbacks to changing...anyone done this and can you point me in the right direction...Cheers...
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA%3AIT&rd=1
Despite what his ad says- they're not re-treads!
