Mini Moto
  • Mini Moto
    Anyone got any tips for starting 2 strokes?
    Haven't started my boys mini motos for a couple of months and they won't start.
    Certainly a good excercise for warming you up though.
    Steve
    Should have bought a 3ltr
    Biggest tip. Small strokers hate stale petrol and it goes very stale in the carb. find the carb drain and open it, drain through half a jamjar full
    Then take out the spark plug and tip a teaspoon of neat 2 stroke oil down the hole.
    turn the engine a couple of times with ignition off
    fit the plug to the plug lead and rest it against the engine. turn it over and check there is a spark (carefull here about getting a shock - marigolds on if in doubt
    put a dribble of fresh petrol (less than a teaspoon) in the plughole
    replace the plug and lead and try starting
    My money is on the stale petrol so this should sort it with a bit of luck
      Both tanks were dry, so sounds about right. will give it a go.
      Steve
        stand away from any fuel.... and pre-heat plug with a ciggy lighter.. wipe off soot and try......
        or put plugs under grill for 5 mins... (turning occasionally ) he-he.....
        should sort you out... done it loads of times in my biking days.....
        also use fresh fuel....
        carl......
        gettin coooooler... and dark....
          If the tanks were dry, you might want to remove the fuel tap from the tank and clean the filter as it may have become blocked with silt from the bottom of the tank.
            Son has gocart and scooter both above are spot on new juice and ciggy pre heat mind they flood easy
            Enjoy the finger blisters
            Brian
              Thanks guys, heard the one about warming the plug but wasn't sure if this was an old wives tail.
              They have clear filters and I can see the fuel which looks OK, will have a butchers in carbs.
              My wrist still hurts this morning
              Steve
                Steve
                Snigger!
                  Yeah - Heat the plug up... we use to use a blow lamp....
                    The alternative method is to leave it unattended on the drive for 10 mins. The local chavs will be riding it around in no time. You just have to figure how to get it back.
                    It's only a hobby!
                      Thanks Chaps
                      It worked, the one that had been not running for shortest period started first pull after teaspoon of petrol down bore and heating the plug with blow torch. The other a liitle more stubborn, I was almost recided to stripping carb when i thought bugger it sling 2 teaspoons in and heated plug. Bingo 2 happy chaps.
                      Just gotta fit new exhaust then off to our own personal race track.
                      Thanks again chaps
                      Steve
