Just finnished putting new springs on the truck... what a difference its made got the roughtrax uprated ones will post photo tomorrow after we go out and bleed the brakes as had to disconnect the rear break line to fit the springs ....has any one else had this problem???
Springs
Originally posted by BUSHWHACKERNope. Did you disconnect the brake line to fit an extended one?
No must have a short flexable connection then ,the springs that came off were longer than the ones that went on and the rear is liftedLast edited by Woodzie; 18 February 2006, 20:30.www.daemon4x4.org
Originally posted by BUSHWHACKERI just made up a spacer for mine to keep the flexy hose.....err......flexy.
I must say that this surf game is so much fun as no two ever appear to be the same .... Oh to be a japanese modification supplier ... i could make a fortunewww.daemon4x4.org
Originally posted by ianwoodzieI must say that this surf game is so much fun as no two ever appear to be the same .... Oh to be a japanese modification supplier ... i could make a fortune
There's alawys a Payback.... You just can't see it Comin !!!!Buncefield Burner
Originally posted by BUSHWHACKERNo worries......
Its those +2" lift coils i want the same pic of really.....ianwoodzie thanks3.0 TD SSR-X LTD 1994 Black, sold and passed MOT
Finally found the camera and some working batteries.(camera just chews them since my lithum on died)...... Next projects are to replace the anti roll bar links as mine are on the way out , get a 2inch body lift off of danno and do the raised breathers just got to get some suitable air linewww.daemon4x4.org
Originally posted by ianwoodzieFinally found the camera and some working batteries.(camera just chews them since my lithum on died)...... Next projects are to replace the anti roll bar links as mine are on the way out , get a 2inch body lift off of danno and do the raised breathers just got to get some suitable air lineTim
Originally posted by ianwoodzieFinally found the camera and some working batteries.(camera just chews them since my lithum on died)...... Next projects are to replace the anti roll bar links as mine are on the way out , get a 2inch body lift off of danno and do the raised breathers just got to get some suitable air line3.0 TD SSR-X LTD 1994 Black, sold and passed MOT
