And so it begins
It continues
got to grips with the head rebuild today,and I must say a hugeTHANKYOU.
to Rick (the mighty vagrant no2 ) for alll his help,he drove all the way from darkest londinium to the outpost of Felixstowe and got stuck in with the job.Sir you are a STAR. Without your efforts I would still be trying to get the on,but as it is thanks to you.......THE SUMO MOBILE LIVES
Just a bit of refitting tomorrow and the jobs a goodun.
its a shame you had to go home Rick cos Angie made enough chicken casserole for 5.and thanks to TonyN for the tappet clearences,hope your bacon did not burnLast edited by sumo; 17 August 2007, 08:11.If the puddles to deep..LEARN TO SCUBA.
Originally posted by GamedawnLooks like a good job - at least you should be fit for Norfolk Did you provide the marigolds or does Rick have his own supply?If the puddles to deep..LEARN TO SCUBA.
Originally posted by sumoThey were his own and they kept his hand all clean and soft,the basement bird was well impressed and wants to know why I dont wear them,so I nicked a pair.Hope she aint got a headache tonight
If I don't wear them the rash on my hands flares up from to many years as a spanner monkey .Rick...Member of 1st Gen club. ONE LIFE ... GET ONE !!
Cheers m8.If the puddles to deep..LEARN TO SCUBA.
Originally posted by sumoGood to see you got home ok I hope you did not speed too much...
Cheers m8.
Thank Angie for the burgers and tea and the cake .
Hope you get the rest back together tomorrow . Any bolts left over are always handy to keep in the tool box for when the item they were supposed to have fully hold on falls off you can then put it back on properly .Rick...Member of 1st Gen club. ONE LIFE ... GET ONE !!
Right the story so far..I spent all day putting stuff back on,you know like the rad and air filter,front grill and the like and I still got bits left over,I'll take apiccy later and if you need any of it yell but its mostly bolts,although I do have an aircon unit,still I digress.
I put in the coolant ran it up with the rear heater on and all seemed well for about 15 mins when the old girl spat out coolant.Not to worry thought I it must be an air lock.But to be on the safe side just incase the thermostat was shot,(cos the old girl got well cooked)I took it out.filled the system again and the temp guage went straight to hot and stayed there,then dropped to normal then went hot and stayed there so I figured that was shot as well.Whizzed down to wilcos but they had none so I had to order them (be here monday).Anyway with the thermostat out she still spits coolant after a while.
My question is What do I do now?
Oh yeah you know that old adage if it aint brke dont fix it WEEELLLL..
While I could get at it I thought I would check the steering box oil level (well on a suzi you undo the threaded nut and screw and fill up from there)so I did the same on my surf but in my eagerness I forgot to jack up the front end.I undid the nut and the screw moved,now I dont know why but I thought NO this aint right so I did up the nut and left it alone. went for a test drive after the rebuild and guess what? yep steering oil is falling out of the bottom of the steering box.......OH BUGGA another job to do.
I am now heading for the bath with a huge glass of wine in my hand to contemplate on life and the world of surfizum.If the puddles to deep..LEARN TO SCUBA.
Is she firing on all 4 cylinders now ? As she was a little 'missy' yesterday which I thought was air in fuel .
You need at least the outer piece of the thermostat or the waterpump will cavitate and it will overheat as bad as if the stat was locked shut .
Are the hoses going rock hard with pressure ?Rick...Member of 1st Gen club. ONE LIFE ... GET ONE !!
Originally posted by Vagrant No2Is she firing on all 4 cylinders now ? As she was a little 'missy' yesterday which I thought was air in fuel .
yep she sure is infact I think she got more vavavaroom
dont get that bit. the thermostat is 1 piece
Are the hoses going rock hard with pressure ?If the puddles to deep..LEARN TO SCUBA.
Does sound like air lock . The fuel cat may not help as it is so high up . I suggest clamping off the fuel cat pipes and bleed out the front heater first , then the rear and finally let the clamps off the cat .
The thremostat is a one piece but in the Zook and other 'specialist' cars I have cut out the centre piece to give a freer flow and slower warm up rate , but you need the outer 'shell' of the stat in place .
Hope this helps mate , dont give up now ,it will be fixed . I can come back down Sunday after next if needed .Rick...Member of 1st Gen club. ONE LIFE ... GET ONE !!
Originally posted by Vagrant No2Does sound like air lock . The fuel cat may not help as it is so high up . I suggest clamping off the fuel cat pipes and bleed out the front heater first , then the rear and finally let the clamps off the cat .
Hope this helps mate , dont give up now ,it will be fixed . I can come back down Sunday after next if needed .If the puddles to deep..LEARN TO SCUBA.
And now its over
The sumo mobile is all back together again now and is doing fine,(dont want to push me luck just yet) tomorrow is a big day for the old girl cos she is off to see THE VAGRANTS as they bash their way round the Mac challenge.Well some ones got to make the tea and bacon butties aint they.Apart from that my MD said it would be nice to have a write up and some piccies for the company mag (with its worldwide distribution) and would I like to go do it,(welllllll as you know if it involves MUD then I am your man) so I said ok.
Mind you that was before this latest bit of bother but its all sorted now so its,
PLAYTIME
dont forget its Norfolk at the end of the month YippeeeeeeeeIf the puddles to deep..LEARN TO SCUBA.
