hic, hic, hic,
  • hic, hic, hic,
    Hi there,
    This may seem like a strange request but has anyone got a cure for hiccups - I've had them for hours!!!!!
    Jacqueline
    Originally posted by jax
    Hi there,
    Jacqueline
    well, when i was a young 'un my dad once told me to hold my breath for half an hour............ he said that'd cure anything..... !!!!
      BOO!
      Gaz
        He, he, hic, he, he, hic, hic
        Jacqueline
          I've heard that copious amounts of Fosters does the trick!!
            try a shot of vinegar, father in law always recomends it but im not sure if he's trying to kill me off!
              find a big old key, put it in the fridge for 10 minutes, then get someone else to drop it down the back of your neck. honest, its not just an old wives tale..
              it's in me shed, mate.
                Hello,
                Well, I hope you're cured.
                But......a guaranteed cure
                Take half a glass of water, bend yourself forward, and drink out of the wrong side of the glass (you will be bent forward almost double, and probably spill some). You must swallow several mouthfuls.
                It will work!
                Regards
                ps - don't do this with your partner anywhere near, you know why.......
                  does any particular type of key work better than another chillit?
                  Simon
                  MPG? Don't you mean GPM.
                    well.... i found a victorian 2 lever iron rim lock key works much better than these new fangled cylinder keys or god forbid a eurolock...
                      When i was a young,my uncle always used to say to me " do that again and i'll give you a fiver".......not once did a get the cash!!
                      So many toys-So little cash
                        for anyone suffering from hiccups... ( i get them a lot, sometimes daily)
                        the absolute best cure i have found is this:
                        firstly:
                        start a cold tap running, ideally a tap you must bend over to drink from....
                        then:
                        using both hands, put a thumb in each ear to block off the ear canal, then reach around with your little fingers and apply pressure to each nostril to completely close off your nose.
                        Now:
                        bend over and drink from the tap, you should feel a suction pressure on your thumbs into your ears... keep the seal, dont remove thumbs.
                        after several mouthfulls of water have been swallowed, remove thumbs from ears and fingers from nose..
                        hey presto... no hiccups.
                        works everytime on me. amazing.
                        she's no angel
                          Hmmmmm. I wonder if that method could be adapted to cure airlocks in the cooling system???
                            best method of releasing airlocks from the system is use the dump valve on the bottom...
                            but you might find if your engine is female it will blame the car next to it or any innocent passing dog...
                            she's no angel
                              every one knows female engines dont need a dump valve at the bottom, cos the head has a chatter valve that doesnt allow the system to build up enough pressure to vent 'properly'
