Replacement Engines and Ancilliaries
  • Replacement Engines and Ancilliaries
    Anyone seen this
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...DME:B:AAQ:UK:1
    Looks cheap, got email from him to say..........
    Our engines are carefully selected in Japan with around 55k on, then they are sent over, we give a 3 month warranty, we also recommend you check / change your radiator as they corrode and cause problems.
    This price is just for the engine.
    If you require a complete kit ready to fit which includes Engine, Turbo, Injector Pump, Starter Motor, Vac pump and Alternator add just £100.
    Delivery is £60
    The turbo on its own would be £150
    Thanks Richard (jap.auto.part)
    Unfortunately he doesn't mention if they have new type heads so presume they don't! And its the old "around 55K". Mine came in the UK with 63 on it, but I have since found out it had nearer 100K! So up to you. I'm still concidering one.
    Turbo price seems ok too
    I NEED TO OFFROAD!
    seems like a good bet - get another engine and sell the spare bits off your old one that havent broken.
    if I needed to spend serious money Id probably do it.
    Tim
