i know this might sound really thick but how do you get at ur spare wheel on 91 model surf estate,do you get to it from underneath the back of the jeep or do you lift the carpet up in the back and get to it from there.
spare wheel
if ya got underslung spare under ya back seats is a few pieces of bar whick lock toghether. put through a small hole in your rear bumper and locate in a small winding mechanism under rear of car . turn mech and it slowly lowers wheel to floor . hope this helpsOriginally posted by brian88883long bar rear seats bumper can you elaberate mate cos i havent a clue.
I,LL GO FIRST NO PROB
(i also juggle dynamite)
cheers mate will have a buchass tomorrow.Originally posted by stimpy30if ya got underslung spare under ya back seats is a few pieces of bar whick lock toghether. put through a small hole in your rear bumper and locate in a small winding mechanism under rear of car . turn mech and it slowly lowers wheel to floor . hope this helps
OK, lift up your rear seat, underneath should be a jack and a long bar with a hook at one end. This hook will fit in the jack to let wind it up, it also goes in the slot in the middle of the rear bumper, feed the bar though the hole untill it locates in the wheel winch mech. You should also have a tool roll in one of the load area side pockets, in here should be a handle that fits over the end of the long bar so you can wind it up and down easily.Originally posted by brian88883long bar rear seats bumper can you elaberate mate cos i havent a clue.
There is a sticker normally on the rear bumper that shows you how to stick the bar in bumper, on some truck it goes in straight and other it goes in at 45 deg to near the chassis rail. If the sticker is gone, have a look under the car to see where it goes.
p.s to get the base of your rear seats up you have to put your hand down the back find a little pull flap which relaeses seat locks then fold base forwardOriginally posted by brian88883cheers mate will have a buchass tomorrow.
to access bars . pps under here is also a small panel under which is your bottle jack to lift car .
AHHHHHHHHH!Originally posted by stimpy30p.s to get the base of your rear seats up you have to put your hand down the back find a little pull flap which relaeses seat locks then fold base forward.
No wonder I didn't get very far yanking my seats with all my might.
Maybe now I can get my seatbelts loose and strap my passengers in properly!_______
/_/ _ | 0\__
\,...__,..._ /
_(o)__(o)_
I forgot the dvla are unable to define a vehicle properly . As UD Trev says some are motorhome/caravan .Originally posted by CaptainBeakyNo, it's not b o ll o c k s, he's just taking the pi$$!
All Surfs are estates (except Tony's hand-carved pick-up...)Rick...Member of 1st Gen club. ONE LIFE ... GET ONE !!
