another interesting question... Snoop any chance you can fill us in on your rebuild...? what, how much, and who did it...? photo's etc...?
What it is like now... how it feels... etc...
absolutely, no problem. TonyN (of 4x4 Toys - 01256 473397 just in case a newbie doesn't know who Mr N is!) did the collecting, dismantling and diagnosing work when we weren't sure how bad it was. Having found the cause to be a holed piston he then also removed the lump from the truck (one big arse engine crane required!).
I then used QEP (Quality Engineered Products - 01444 243720/www.Q-E-P.co.uk) to do the assessment of how bad the block/head had warped etc. They then also did the basic rebuild. This included:
Block skim
Head skim
Engine bore
Oversized pistons
Crank regrind
The block then went back to Tony to be mated to the head and then put back in the truck and setup. We also put in Diesel Bobs uprated injectors.
I haven't fully run the engine in enough yet to be able to give it full on beans and check the power, but it is definately much, much smoother and it is soooo quiet! At tickover it sounds like it did before, but when it is running we really can't even hear it in the cabin. It has completely tranformed the engine for the better, it's so nice. I don't know how much can be attributed to the oversized pistons/skimming etc. or the new injectors. It would have been nice to try the injectors on standard first to see the difference. Either way, I'm Well happy
Price-wise, between 4x4 Toys and QEP the total amount was just under £2K. As they tend to with these things, the price reflects the individual circumstances and I'm not sure I'd count on it being so cheap.
As for photos, there have been some posted by Tony when the engine was on the stand and then being put in the truck - I'll try and find the link. As for how it looks now, it looks exactly the same as it did before only cleaner!
