I have purchased a 94 3.0l with 89Kms showing. The car was purchased from a dealer (fresh import) with the understanding it would be fully serviced and prepared. He refused to change the cam belt saying it was changed in November 2002. However he has not supplied any proof of this other than saying it was said at the auction in Japan. I have looked at the belt, it is shiny and the lines of the teeth can be clearly seen through the flat outer face. I do not think it is newish. What do you folks think from experience?
They won't change my cam belt?
Originally posted by RobFI have purchased a 94 3.0l with 89Kms showing. The car was purchased from a dealer (fresh import) with the understanding it would be fully serviced and prepared. He refused to change the cam belt saying it was changed in November 2002. However he has not supplied any proof of this other than saying it was said at the auction in Japan. I have looked at the belt, it is shiny and the lines of the teeth can be clearly seen through the flat outer face. I do not think it is newish. What do you folks think from experience?
Ask the dealer to confirm in writing to you that in their opinion it is a new belt and does not need to be changed,
see what their reply is
KeithI never ever apologise for anything. http://www.onestopshopformultimedia.com/smile.gif If you dont like it I am sorry but thats the way I am
It's a minefield and you are unlikely to change the dealers mind. The only safe option is to have peace of mind and change it.Originally posted by RobFI have purchased a 94 3.0l with 89Kms showing. The car was purchased from a dealer (fresh import) with the understanding it would be fully serviced and prepared. He refused to change the cam belt saying it was changed in November 2002. However he has not supplied any proof of this other than saying it was said at the auction in Japan. I have looked at the belt, it is shiny and the lines of the teeth can be clearly seen through the flat outer face. I do not think it is newish. What do you folks think from experience?
Rich.If life's an uphill struggle then downhill from now on can't be that bad?!
You can see if you can get it in writing then if it goes you claim against him although you will still have a problem, cause he's only going on what he was told supposidly.Originally posted by richIt's a minefield and you are unlikely to change the dealers mind. The only safe option is to have peace of mind and change it.
Rich.
Safest bet is change it yourself, milners do the belt www.milneroffroad.co.ukSay not always what you know, but always know what you say.
My 4x4
My choice
Back off
Hi,
Gotta agree with Rich & Koi - The only way to be sure is change the cambelt yourself. Its an easy job and doesnt take long. I always change the tensioner at the same time (it's only £9 something plus vat from toyota) Also make sure all the pulleys are ok.
NeilSmith & Wesson: the first point & click interface
Total agree with all.
Foot note to say changing the Cam belt is easy and can be don't by anyone with a 12mm socket and a screwdriver.
The japanese put stickers on the car when they did stuff like changing the cam belt. have a look around and maybe your find when they changed the belt.
you can PM me to find out how to change the beltScubaSurf
The place to be is under the sea
No but then again it isn't that difficult just more time consuming. You need to remove the viscous fan, radiator shroud, crankshaft pulley, all the belts and some hoses (or at least move them out the way).Originally posted by icsysIs it as easy to change a 2.4 as it is to change a 3lt ?
Then you can remove the timing belt cover and change the belt.
Should take a couple of hours at most if everything comes undone.
