just fitted my towequipe tow bar.but not sure if you should slide a backing plate in to the chasie or if it is strong enough can anyone help please
tow bar fiting
Originally posted by Chillittthere should be a plate with captive nuts that goes inside the rail. that should be plenty strong enough.. you might also need a spacer to stop the plate behing the hitch itself hitting the bumper
yes there are two captive nut's ware the tow eye bolt's on then two at the other end, the plate's i thought were the backing plate's must be said spacers
thank's a lot
www.floatingpontoonsolutions.co.uk
Originally posted by stevieboyjust fitted my towequipe tow bar.but not sure if you should slide a backing plate in to the chasie or if it is strong enough can anyone help pleaseNow I Have Grown Up, I Need A Grown Up Tonker Toy!
