Running at moment with 20 litres of new veg oil in the truck and topped up to full with derv. white smoke on start up and stinks like a chip pan thats been left on a bit too long.
Also rough on startup for about 10 seconds then settles down to run quieter than on straight derv.
Power is the same and no side effects other than the stink and the choppy start up.
This is about 33% mix with the surf's 60 litre tank, I would not like to go any higher than this and probably will discontinue the use of oil after this trial as I just want to know what is and is not poss.
hope this proves of use to you all.
Al.
Al.
