Hi All, Dont know if this will be of interest to anyone, I want to fit four pos
six X 6" angel eye spots (stainless) on the Jaos i've just put on but didnt want to see a lot of brackets and wireing etc, As the jaos only have two
fixing points for lights i decide'ed to make something that would hold all six
spots (4up &2down eitherside of no plate) and hide all the wires, As the
thumnails show (if they show up, first time i've done pics) i made a type of box section out of a shower door top rail with a removable back, Easy to fit
and all wireing can be tied and cliped and run through the box exiting at one end with a protective covering, spiral wrap or similar, through a gromet, To make it easer to fit the lamps all i have to do is loosen the center bar bolts and remove the two lower side bar bolts in order to swivel the bar round and
fit the lights, Note! it wont swivel quite so far if i fit two lower lights but should still be enough to see what i'm doing, All the bits are alloy, stainless
would have been better (but harder to work) Anyway all polished up it looks
ok, All i need now are four spots and two fogs (or six spots) hav'nt made my mind up yet, Then five marker lights and a roof bar full,Then a flat battery
Cheers All Ian
Cheers All Ian
