recovery points
  • recovery points
    any of u guys added recovery points on the back.
    where the original points are , are to far under the car and you cant get to them if you are stuck in deep mud.
    if you have, a wee piccie would be appreciated, so i can see what you have done.
    or am i as well sticking to haveing the bridle attached with the kinetic rope in the back window.
    thanks again scotty
    towbar or big wellies for me
    but dont get stuck
    just attach your straps or ropes before you hit the mud mate
    Enjoying Life after Cancer
    Pops
      but dont get stuck
      works for me, forward thinking
      does not do to wrap rope around the bullbars all the time, unless you leave the end of it in a sensible place..............
      gwyn's truck......yes his rope is in the s..t
        run my truck with a 2wd hilux tow bar, not sure if this would fit a surf though.
        Diesel, like petrol only better
          The points under the back of the vehicle are lashing eyes, not recovery points. The best thing to do is fit a tow bar - this gives a recovery point and protects the rear bumper
          Roger
            Or to have one made specific...like those at sonoran steel over in the states etc..
            Gaz
              You should tie up and feed the free end down through the sunroof. Move the sunroof forward to grip the strop tight.
              If you get stuck- simply open the sunroof, stand up and throw the free end at your rescuer!
              Same with the back recovery rope.
                i use the points under the back of the vehicle the lashing down eyes, with a bridle u can get them off the forum shop for £15.50. I have never had any problem using them and i always put my straps on front and back before i go play.
                  Do you wear BRACES chris
                    yes make leg braces
                      You need some of these for recovery
                      BALLS of steel these lads.
                        oh my god.....
                        TeaM BOFA4x4 Mac 2008
                        www.bofa4x4.com
