Rear window used to go up and down smoothly (if a bit slowly).
Then it only went up and down in stages.
Then it only went up and down (in stages) if you used the key in the back door.
Then you had to coax it a bit with your fingers (hubby nearly lost a few!)
Then it was plain old stuck
Motor still sounds, window not moving....have looked in, greased the cog bits, it is up so we have left it....its not too handy getting the buggy out over the kids heads though :-)
Don't tell me, I need new batteries and I will have to have the engine out to get them in, the batteries need to come from Tokyo and I am sure there is a 'harness' or something needed....or maybe I am just repeating the last 5 posts ....giggle :-)
At least you didn't try to open the window when the door is down.
Works if you flick the catches.
Luckily it hit my leg and a hammer fixed the bent bits
And it goes up and down a treat now!
