ok I might have got to the bottom of my 4wd woes ( not engaging)..... just had the bonnet up to reset the ECU, batteries off.
Found a short piece of rubber tube, about 7 to 8 inches long, just lying by one of the batteries, it has spiral binding around it.
Did some searching on the drivers side inner wing, found a rubber tube coming from the inner wing and followed it to a "3" way connector, a short section of tubing then goes from the 3 way down to what looks like a vacuum pump on the front of the alternator. BUT..... one side of the 3 way connector has nothing on it, I am GUESSING that this short section I found fits on this connector ?? if I am correct, what does it then attach to.??
You aint seen me, right
