hi guys,
just had a problem with a leaky injector pump and had it fixed. i dont know what the freaks did but now the truck is hell slow with reduced power and is also smokes like hell. you think the injector is screwed? pls help.
Did you fix it yourself, or take it to a garage? If the pump was removed to fix the leak, then it sounds like the timing hasn't been lined up correctly. If the belt is one or two teeth out, it will give the exact symptoms you are describing.
