Engine oil low the other day, so filled it, went to correct level.
Then next day too high.
So tonight when i got home from work in other car, thought i would remove filter to get rid of a bit of oil. Engine cold and not run for 24 hours.
But filter empty and looked very very clean inside.
would this be normal? would oil all drain out overnight and leave it looking shiny and clean inside?
or has oil not been circulating through filter for last 3000 miles.....?
is that a possible? hope not as terrrible for engine...
i put a new filter on, with a bit of clean oil and that filled up after i ran engine for a minute
tried original, that filled up a bit this time, but hiss of air when i removed it.
hope this is a panic over nothing..
