hmm little car vrs. big car
Ouch!
You don't swerve for a pheasant - you just hit it, then go and pick it up to make pate!
Hit a pheasant in my Golf a few years ago - can't recommend it. About £120 for new headlight grille, one new headlight and a set of mounting clips. By comparison, a 12-bore cartridge is around 12p, and makes far less of a mess of the bird - far more economical
After hitting one in the car, pate really was all it was good for.
On the other hand, I read (in Autocar, I think) about Saabs being tested for impact with elks! To save wear and tear on real live elks, to improve the repeatability of the test and to forestall a blizzard of protests from the bunnyhuggers, Saab built a replica elk using a sheaf of power cables wrapped in rugs, and stood it on wooden legs at the right height, so that when the car hit it, the "body" landed on the bonnet and hit the windscreen, just like a real elk. Given that an adult elk weighs a good half tonne, the usual result used to be that the body of the elk would remove the top of the car, including the top of the driver
This apparently, is why Swedish cars have reinforced A-pillars. They also have to undergo a "swerve test" (also called the Igtest or Elktest) which simulates swerving round a large object that has suddenly appeared in front of the car, and then resuming the original path.
Here endeth the digression
Peter
I am not a number. I am a FREE MAN!
When british rail tested its high-speed trains it used a piece of kit borrowed from NASA that they used to test the windsreens on the shuttle.Its a cannon that fires dead chickens at windows. British rail proptly fired a dead chicken at the windsceen of this train it smashed thro the glass,thro the seat and embedded itself in the back of the drivers cabin,worried about the results they sent the telemetry back to NASA. The reply that came back was.....defrost chicken first.
[SIZE=5]A bad days fishing is better than a good days work[/SIZE]
I have heard this elsewhere - apparently thawing the chicken makes no appreciable difference, 'cos the mass and velocity of the chicken are unchanged, hence the kinetic energy transferred to the glass are the same.Originally posted by FISH EAGLEWhen british rail tested its high-speed trains it used a piece of kit borrowed from NASA that they used to test the windsreens on the shuttle.Its a cannon that fires dead chickens at windows. British rail proptly fired a dead chicken at the windsceen of this train it smashed thro the glass,thro the seat and embedded itself in the back of the drivers cabin,worried about the results they sent the telemetry back to NASA. The reply that came back was.....defrost chicken first.
Various websites list this urban legend, and debunk it - here is one example.
RegardsPeter
I guess the moral of the story is to drive a kenworth, the pick up that j Leno tested in the Sunday Times Driving section or to buy an armoured personell carrier!
or to live boarded up in your house, surrounded by tank traps etcOk nicely done, when we dry off we can go find the boat!
Originally posted by CaptainBeakyI have heard this elsewhere - apparently thawing the chicken makes no appreciable difference, 'cos the mass and velocity of the chicken are unchanged, hence the kinetic energy transferred to the glass are the same.
Regards
yeah, 'mythbusters' did it a while ago, as said no differenceSay not always what you know, but always know what you say.
My 4x4
My choice
Back off
That was the test that caused the recall of the Merc A class when it was first introduced - it fell overOriginally posted by CaptainBeakyThey also have to undergo a "swerve test" (also called the Igtest or Elktest) which simulates swerving round a large object that has suddenly appeared in front of the car, and then resuming the original path.
Roger
