what wheels drive
I think....
AWD = all wheel drive - like on my subaru, its always sending power to 4 wheels, with centre viscous differential to accomodate wheel rotation speeds, and distributed power between front/rear axles if need be.
4WD = four wheel drive - with a centre differential locked. As in a 2nd gen 4runner/surf, or 3rd gen with the diff locked.
A 3rd gen in 4wd mode without diff-locked, maybe different to AWD, as the centre diff is open, and not a limited slip diff type like a subaru
my tuppene worth anyway..Landcruiser Colorado
Sub. Forester
Originally posted by Un_discoveredWhat the hell is the difference between AWD and 4WD ?? The only way there would be a difference is if you had a 6 wheeler
Its the way of making the distinction between 4wd systems, AWD (all wheel drive) is usually refered to for road cars with '4wd' and always have a center diff, but an open center diff offroad leaves you no better than 2wd as the center diff will slip and give power to front or rear axle only. Then you have to lock the center diff, giving you 4wd the same as a 2nd gen Surf in 4wd.
