Suspension Lift Finished!!!!!!!!
  • Suspension Lift Finished!!!!!!!!
    just finished my suspension lift (thank god ) just a little question how do i adjust torsion bars? as front does not seem to have gone up do i need to jack up truck again? or do i just unscrew bolt?
    If you changed the bolts it is possible to just tighten them, but it would be easier with the front jacked as that releases the pressure from the Torsion bars. Remember that the suspension settles after moving, so once you've adjusted them after driving 100 yards they'll need adjusting again (unless your really lucky).
    Did you change the bars with uprated ones?
    Gone from 4x4 to 1x2
      24mm socket i think, tighten to go up. Loosen to go down. Youll see the bolt heads roughly inline with your transfer case.
        have fitted uprated bars i have been turning wrong way then i thought it was loosen to raise is it definitely tighten to raise
          some more pics will try to get some better ones tomorrow
            Lookin' good there, which kit did you use?
            Damian
            http://www.themudlife.co.uk
              2" kit from explorer it's a pro comp
                Warning!!
                I seem to recall reading somewhere (Openback's post #7 here http://www.yotasurf.co.uk/forums/showthread.php?t=14229 )that its essential to adjust the torsion bars with the front wheels OFF the road - i.e. no load. People have had the vehicle collapse on them as the torsion bar broke when trying to do this without properly jacking/supporting.
                Kev
                  Just wanted to say that it looks awesome mate!
                  Rob
                  Constantly Striving to Attain Lower Standards
                    I am thinking of tackling a lift the same as yours it looks great
                    can you give any info such as
                    best order to do the job in
                    any snags probs and tips to deal with them
                    all and any advice appreciated
                    cheers
                    Bobo
                      LOOKIN GOOD!!
                        Kev
                        WOW I've been quoted maybe this is the time to come clean, when i said people have had their truck collapse, people=me!
                        lookin' good what size tyres are you running?
                        Diesel, like petrol only better
                          Fine looking truck dude!
                          What size are the tyres?
                            Jedi's truck is now owned by 'stevehulluk'
                              I am thinking of tackling a lift the same as Jedi's it looks great
                              cheers
                              Bobo
