Hi folks,
Just about to prep my new toy for SVA, can I pull on experiences to clarify some points please - this is a 1996 :-
1) Do I need a gearbox for speedo cable or a chip to alter KPH -> MPH ?
2) I understand I need rear reflectors? What size and location should these be please?
3) I have the window deflectors, I would rather not remove these. Will I get picked up on them? I dont think they are sharp, but............Should I stick some rubber trim along the exposed edges?
Just to clarify I also believe I need to do the following, have I over looked or missed anything please?
1) Remove rear tyre/carrier
2) Check for sharp edges
3) Check for loose wiring and secure
4) Remove the turbo timer and remote start
5) Rear Fog light
6) Depending on speedo option a MPH sticker over the KPH
Rgds and thanks
Ant
1996 SSR-G 3.0 TD Intercooled
5) Rear Fog light
Rgds and thanks
Ant
Sod's law says that if I dont follow everything to a T then I will have the strictest tester in the world! Starting the work today, although still need to find :-
