Roof rack for 2nd Gen
  • Roof rack for 2nd Gen
    I want to fit a roof rack to my 2nd gen surf
    I will be drilling and bolting it through the roof
    I think I have read on someones thread that there is strong points in the roof
    Can anyone help on this
    Thanks Ian
    Thanks Ian
    Just a point, wouldn't it be better to mount it on roof bars ?
    Then you can add or remove it at will, and no holes drilled
    Trev
      and there were 2nd gen roof bars for sale in the for sale section
      http://www.yotasurf.co.uk/forums/showthread.php?t=12610
      Landcruiser Colorado
      Sub. Forester
        Trev
        Thanks but this is now a work Vehicle so I need a heavy duty roof rack and will be a permenant fixture
        Ian
          There are roof braces underside of the exterior roof skin. They are by no means very strong. You can bolt through the roof skin into the roof braces, and mount to all of them to spread the load. However, a note of caution. Do not place too much weight up there, things will still flex, and in motion, it will get "interesting".
          You can get some more internal roof braces from your friendly and helpful Toyota parts monkey and weld some more in to give more 'capacity', but that is not where you want to carry anything substantial. You will have a real limit of about 200 - 250Kg. Even that will get "interesting" when moving the vehicle about. I've had 500kg up there, and lets just say on a short trip to France, not something I would recommend or encourage.
            Many Thanks for that
            It´s not so much weight more a case of bulky stuff or long (ladders / long lengths of steel)
            I will try my local Spanish Toyota Dealer for the roof braces (that will be fun) lol
            Ian
              These are the internal braces that hold the side panels/frame together whilst they weld the roof section on... (at least thats what they look like)
              Should be a standard body part. As long as you can get the right part number... I'll try and have alook later on at my EPC...
              andyL
                andyL
                Do you know how many braces there are and where they are or is it just better to take down the headlining and align the roof rack brackets to match
                As for the parts I don´t think Toyota´s in Spain even know what a Surf is i´ve been in my local one and " they have not got a clue " (lol)
                Thanks Ian
                  Thanks Ian
                  They must have some clue cos my Surf has had brake pads fitted in Spain somewhere at Toyota
                  Tim
