Rear coil lift over 2"
  • Rear coil lift over 2"
    Seen as I havent noticed anyone mention this before around here, I suppose I should.
    Reading on another forum I've found that instead of going for +2" springs in the rear to eliminate butt sag and do the "2 inch suspension lift", you can instead go for a direct 3" to 4" lift by installing J80 series (land cruiser) coils. This would be the top of the range LC which roughly corresponds to the years of the 2nd gen surf. Lucky owns one. Apparently they are a straight swop in.
    You need extended brake lines and a panhard job done but thats it. A number of people including the recently re-arrested Delboy (he's back in the hospice for the bewildered ) werent happy with the lift the +2" coils give so maybe this is worth a try.....
    shhh, he won't let me near it cos of the lockers, if he find out I need the coils as well i'll have no chance.
      Nice. maybe the brake hoses will fit as well????
        Found more,
        http://www.allprooffroad.com/index.p...ask=view&id=45
        Holy flip $239 for 2 control arms thats outrageous. Maybe this setup is exactly what you get for the rear in a 4" suspension lift from LA Supertrux, anyone??
          You got me thinking now!
          Are these the springs????
          http://cgi.ebay.co.uk/ws/eBayISAPI.d...sPageName=WDVW
            As ive posted already i'm getting 'cruiser 80 rear coils for my 1994 Surf from Millners for £40, luckily ive got an adjustable rod so i should get a good lift and the back end shouldnt sag so much when load is in......
            Will report back when its done
              I can't wait to see what your back end looks like.
              Er, of your truck that is, ahem.
                If you lift the rear 2", by using longer springs, you crank up the torsion bars by an equal amount. How do you raise the front 3"? Just curious.
                It's only a hobby!
                  Well there's always the option of raising the front using balljoint spacers like delboy has, helps keep the rest of the front geometry closer to stock too.
                  Maurice
                    Have a look here.
                    http://www.yotatech.com/showthread.p...highlight=lift
                    Jez
                    __________________________________________
