Pop's The Plonker
    Originally posted by pops
    anyone know if you can get the tailgate open with the window up
    If the window is FULLY up then you got no chance without breaking the said window or ripping the guides out above the tailgate.
    Trev
      Trev
      Bugga wot a way to spend a lazy sunday like i had planned
      been more busy today than a normal sunday DOH!!!!!!!
      Enjoying Life after Cancer
      Pops
        Trev
        if you take the interior trim off, can't you wind it manually??...
        if it's a faulty relay, just connect a +ve contact onto the motor and it should go one way or the other.
          Tonnes of stuff on the forum about this Pops Sounds like it may be a relay which is bad news as it's a £385 box behind the nearside rear panel & it's a pain in the ar** to get out.
          Quick fix........chop the wires to the motor.....crimp some bullet connectors on.
          Now you should be able to swap the wires. This makes the switch think its going up instead of down & vice versa.
          If you leave these handy to get to , you can change them as needed to wind the window up and down.
          If this works.......it proves your motor is ok & your problem is either a switch or a relay.
            ta geoff will have to wait till tomorrow to try that as me crimping gear in my works van
            Pops
              CRIMPING GEAR? Do you do PERMS & HIGHLITES as well
                back to the thread a minute
                overheated again this morning on way to work
                after rad was flushed out yesterday,
                got her to local garage back of work, found thermostat was jamming shut
                new stat fitted, i was 2hours late for work and still watching the temp gauge
                roll on langdale
                Pops
                  Poor Pops, fingers crossed......
                  • #24
                    will that help??
                    and looks like the tailgate motor is ****** too
                    going to save up for a
                    Pops
                    • #25
                      will that help??
                      Originally posted by earlier thread
                      The rear window motor is indeed shared with a few other Toyota models, you will have to make sure to get one from the correct side of the car as they are handed. This has been discussed a few times on the forum before, according to this thread you require a front passinger one from a carina, supra, or corolla, not sure which years tho.
                      Try using the search feature on the toolbar above, it should help you find more details on how to strip it down etc.
                      1
                      • #26
                        1
                        thanks 1 i will try to source 1
                        Pops
                        • #27
                          hehehe!!... wanted to post just the quote, but computer said no!... had to type at least 1 character... so i did!!
                          • #28
                            1 (thats another 1) te he or is that 2 now???
                            Pops
