Painting Alloy Wheels?
  • Painting Alloy Wheels?
    Just a thought, I wondered if it would be a good idea to paint my alloy wheels as a cheap way of tarting them up, rather than paying £100s to get them refurbed.
    Anyone tried this?
    Not to the Surf, but yes done this before...
    Worked out well and looked good - the key is preperation: sanding, priming etc
    (I even managed to remove scuff marks and a dent by using a filling primer)
    [COLOR=Red][FONT=Century Gothic]the unexamined life is not worth living...[/FONT][/COLOR]
      Whenever Ive done it, I've used a tin called "5 wheel silver" (i think) and always comes up with a good finish. Its about the same coulour as a factory alloy and is easy to use.
      Charlie Don't Surf..http://static.photobox.co.uk/public/...10805138.s.jpg
        Now now, you bad people, how am i ment to be able to afford my holidays this yr with you lot doing the wheels yourselves.
        Only joking
        If i can be of any help, with paints,fillers,discs,anything else or just some advice then please holla, ill do my best to help.
          Thanks Guy, I'll give it go.
