Removal of stickers / body labels
  • Removal of stickers / body labels
    My surf has 1 foot high "off road" written down both sides full length of vehicle - which I hate. They appear to be made of the same material as the common "surf" decal seen on a lot of models.
    Any clues how I can get these stickers off without destroying the paintwork?
    Hints and tips greatly appreciated.
    Regards
    Paul
    .......because I can....OK!
    2.4 TD manual 1992 SSR-X
    Regards
    Paul
    Covered many times before here, there is a special tool available, a kind of eraser wheel which is highly recommended by many users on here.
    Have a search, you'll find all the details and pictures too
    Maurice
      A friend has just removed all the decals off his car (not a surf) he borrowed my steam cleaner and used the window cleaning soft pad ,the decals came away without any damage even the adhesive or most of it came off, might work on yours!
        this is the tool you would be looking for........smells like caramel...MMMmmmmmm
          They are great to use , and as Fieldy says they smell really good when being used . You finish the decal removal and leg it to the shops for a Caramac bar . Yum .
            I tried the hairder and then white spirits, takes ages
            Boiling water poured on direct from kettle and pull off as much as sticker as possible before surface cools (watch it 'cos it gets damn hot), dab residue glue with cloth wetted in petrol, and scrape of with plastic scaper...I used an old bank card. Keep wetting with petrol for stubborn bits it breaks it down fine
            Bit of T cut/polish and you'd never know they were even there.
            Scuddy
            Look out! Ee
              I used a paint stripping heat gun (carefully) to do my last surf. Just heat up the decal for a few seconds (from a suitable distance so you dont damage paintwork) and then get an edge off with your fingernails and then carefully start to peel.
              Got rid of the glue residue with some tar remover stuff.
              No longer a Surf owner.
                Decent hair dryer,ice scraper then petrol to remove the residue. Be careful, it will take a while too.
                French fishing at it's best www.mayennefishing.com
                  who do you think you are?... frickin gemini??... what ever happened to him anyway?
                    Hair Dryers
                    Regards
                    Paul
                    I had all my Jap stuff taken off professionally - so saying all they did was to use a hair dryer to soften it,followed by some solvent stuff to clean up the original gel coat afterwards.
                    Surfin
                      I very stupidly jet washed the decals off my truck, and once I realised what I had done had to carry on at get them all off. This left the sticky stuff behind which I got off with Tar & Sticky Stuff remover (got it from Screwfix) and a Boots Advantage Card!! It took me about three hours to do both sides but soon got the knack and after a good wash and polish with Maguires it looks fine.
                      Andy (the girly)
                      What YOU want something THAT big for???!!!!!
