Hey guys Im new to this forum.
So as the title says I have a problem related to the suspension of my ln107.
It all started while I was slowly reversing, I suddenly hear a loud bang and afterwards I have noticed that the truck leaned a little to the left I have measured the wheel gaps on both sides, the left side is 2" lower then the right side.
The steering wheel lost alignment, you need to have it steered 90° to the left in order to drive straight and also the rear end of the truck is extreamly bouncy, on 1 small pot hole the truck bounces multiple times.
I had a look at the torsion bars they seem to be in good shape and the shock absorbers do have some oil but it's not fresh, I would assume if the shocks broke it would leak fresh fluid but I'm not sure about that.
What else could be the problem? I still think it could be the shocks but I'm surprised that they could fail instantly I thought maybe they start to fail slowly by time not in a split second because the truck had a good ride to it before this happened.
