Hi new here I have a 94 surf ssxr 3.0 TD. Truck will not start. I have revamped the injectors and changed the glow plugs and fuel spill vavle. It takes a while to start then won't stay running and blows smoke the whole time. Hope someone can help thanks
Starting problem
I removed the fuel pump and removed the 3 filters from it clean them and used the air line to blow everything out of the pump then changed all the rubber seal on the pump. And the one little rubber seal on the drain plug of fuel filter. After that primed the pump first turn if the key she started
