14) INSULATION
I wanted to insulate the truck for a few reasons:-
a) For deadening for the sound system (more on that in next post). ESSENTIAL if you like your music!
b) To reduce road noise
c) For heat insulation
I used three main products:-
1) Sound insulation
- Silent Coat 40 Sheet (375x250mm)
- This stuff is self adhesive, and can be cut
- I would normally buy dynamat (which I used on the 2nd gen), but that stuff is darn expensive, and with wanting to do the whole truck, I wanted to find a cheaper alternative which was still just as good
- I read a whole bunch of reviews, and spent considerable time doing research, and "Silent Coat" ended up being the next best thing to Dynamat, but much cheaper
- https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1
2) Heat insulation on a roll
- Yuzet 1711 1.2m x 25m Double Aluminium Bubble Insulation
- This I applied AFTER the sound insulation. So the sound insulation was stuck to the inside of the body (see pics), and then I added this stuff on top. It was then secured with the silver tape (below)
3) Silver tape
- This was used to join the pieces of heat insulation
1) Sound insulation
3) Silver tape
