I'll be honest with you here mate, 37" tyres on a 2.4 is a complete waste of money. You'll be lucky if it can drive over the kerb!
You'll need at least a 3" suspension and 3" body lift, perhaps a lot more, that's only a very rough estimate. The mods to lift a truck that high are expensive and pretty labour intensive. I'm believe you have to re-gear the diff as well, I'm sure I read something along those lines.
you will need at least 3" bodylift and about a 5" suspension lift to fit 37's.You then have everything to adjust like the gear levers and steering shaft.It's alot of work unless you got the time to do it
i've seen surf's on 2inch +spring's with 33's on hell i see one evey time i look out my window ............... and there's a surf on 35's up the road on a 4inch body life and noting else
Body lifes are good, but expensive, but with body LIFT it won't work....it can't work with 'just' 4" of lift, it'll rub like hell, most 33's still rub with 4" of lift as soon as you go offroad.
