My Surf was described as having a 3" suspension lift although I think with the Rancho shocks it might be taller. From the floor to the top of the light bar it measures 7ft.
You normally need 4'' of lift to get 33's on - and the usual route is 2'' body + 2'' suspension. And then you will still have to chop out various bits of the front.
Your wheel offset will also influence the fit......
To get 35's on, mmmmm, that is a big tyre. Best of luck.
