Hi everyone, I am looking to buy a gps system for a winter skiing trip in Europe in my surf. I have a PDA and tried using the gps on that but it was ****. I want to buy something like this (http://www.handtec.com/acatalog/copy....html#a1_21158) but know nothing about gps, any advice?
Gps
Originally posted by Pika1971Hi everyone, I am looking to buy a gps system for a winter skiing trip in Europe in my surf. I have a PDA and tried using the gps on that but it was ****. I want to buy something like this (http://www.handtec.com/acatalog/copy....html#a1_21158) but know nothing about gps, any advice?
try looking at the following site: www.globalpositioningsystems.c o.uk for a variety of kit and links
or www.pocketgps.co.ukGaz
The GPS depends upon you unit....I have a IPAQ With an Arkon [Sirf-ii] cradle and thats fine. Some software you may have to set up using the NMEA configuration [like memory-map on mine, even though there is a setting for SIRF connections]Gaz
Im running Tomtom too , I use that for on road stuff . then you can use the Tomtom reciever to feed the data to other bits of software. I use Beeline GPS for walking to co-ordinates when geocaching and a gem of a software package called GPS TUNER , which you can create your own maps from jpegs , ideal for greenlaning as you can see contours as well. All this runs on a IPAQ 2210 with 512Mb memory.Originally posted by GizmoI use an IPAQ 2210 running TomTom v5.0 and just recently added Memory-Map v5 softwarehttp://www.darksidesolutions.co.uk - Web Solutions
I use tom tom 5 every day in a artic and recently i took it over to the US to which it performed with no problems at all.. One thing i will suggest to anybody thinking of going the PDA route is to get a amplified cradle mine has a receiver built into it saves all thoughs orrible wires across the dash, as if i havent got enough wires with HF radios in the back of the truck as well..Im not a gynacologist but ill have a look
i have it on my phone O2 Xda IIs and i love itOriginally posted by mark g8awoI use tom tom 5 every day in a artic and recently i took it over to the US to which it performed with no problems at all.. One thing i will suggest to anybody thinking of going the PDA route is to get a amplified cradle mine has a receiver built into it saves all thoughs orrible wires across the dash, as if i havent got enough wires with HF radios in the back of the truck as well..
just getting it in all my vans and my 7.5 tonner how do you set it up to avoid low bridges????
its not something i ever worried about before
[url="http://www.frappr.com/smurfowners"]Surf MAp[/url]
you can not set it up to avoid bridges......unless you want to spend hours setting up avoids
if you log onto www.pocketgps.co.uk and look at the forum pages their is a guy on their giving the database away with 2000 bridges to use as POI`sIm not a gynacologist but ill have a look
If you can install POIedit [free software] you can then automatically set up preferences to download items from the database [poi own needs subscription] but you can then autolink to the pocketgps sight for the info...there is low bridges on there.Gaz
