My Surf has "Normal" 4WD, not "Multi-Mode" 4WD (no limited slip diff function). I'm under the impression that the "normal" 4WD in my car should only be engaged in very slippery conditions to avoid knackering anything. The (very basic) book that came with the car says that it can be driven on "wet and greasy" roads. So would I be ok to engage it if the road is wet? I was just going to reserve the 4WD option for when it's REALLY needed (ie. stuck or likely to get stuck). Thanks for your advice.
Tell me about 4WD - newbie seeks advice
Originally posted by gwh200 View PostAlso with a decent set of tyres, you'll be pleasantly surprised quite how far you can get.
Ahem!
Sorry, as you were..."B.A." Baracus: "Talk to me, talk sense so I can talk back. Not all this jibberjabber like breaking the peace and all that."
www.johnthebuilder.info
