CV boot change
i know its not the hardest change and many have people haev done it but though while changin mine would document it so anyone who doesnt know how to do it can follow the back yard mechanic steps haha
1) undo the 6 bolts between the front diff and CV. can only do 3 at a time and then have to jack up the wheel and spin it around to get the other 3
2) (optional but easier) use a scissor ball joint splitter to remove the lowest bolt off the diff as it make it easier to get the CV out
3) remove wheel and crack the end cap off using a screw driver and hammer
4) unscrew the bolt out from the end
5) unscrew the 6 bolts in turn dont take them off though till you have popped out the inner piece using a hammer hit directly over each one
6) once you have removed the 6 bolts and the flange there will be gasket paper between that and the hub so it made need to be replaced when refitting, next there is a snap ring (PITA) remove that (still trying to find the best way)
7) sorry to the professional mechanics here remove the 54mm nut either with the proper tool from rough trax or backyard meachanic it with a screw driver. there are 2 and a washer
8 ) then can remove the CV from the truck this is where removing the lowest bolt from the diff makes it a bit easier
9) remove the ripped boot and remove the snap ring to take off the end bearing so can place the new boot on and then do the reverse.
hope this is OK
hope this is OK
