mornin' all
new shocks & springs for all round arrived yesterday from Roughtrax. Planning to chage them over this weekend but even though i've done the rear springs & shocks before (dead easy) I've never touched the fronts.
Having had a quick look last night it looks easy enough but just wanted to check if my thinking is right for changing the front springs
1. jack up under suspension (to keep spring compressed)
2. remove front wheel
3. put another jack under front crossmember
4. fit spring compressors
5. lower jack under suspension
6. remove spring
7. fit spring compresors to new spring & reverse of the above
is that it or do I have to do anything else, do I have to remove the bottom shock bolt. Checked using teh search function but nearly all the info relates to the rear's and I'm OK with them
any advice would be appreciated before the "effing & jeffing" starts
ta
hawaii
6. remove spring
ta
hawaii
