Timing belt crankshaft cog
  • Timing belt crankshaft cog
    How do i remove the crankshaft timing belt cog to allow me to replace the front crankshaft seal?
    STEVIE J
    hi mate.
    you will need to take off rather a lot.do a search on the tech bit,but it does involve removing /loosening a fair bit
    Non intercooled nothing.
      On what engine????
      Fill in the details in you profile.
      This may help.....
      http://www.toyotasurf.asn.au/techsite/
        nice silver star vince !!
          Oh yeah, hadn't noticed. Thanks Koi.
            silver stars
            common as muck now
            www.cnpbetterhomes.co.uk
              are they really ?
                truck type
                sorry guys....I got a 92 ssrx turbo diesel.........I've been on the aussie site and it dosn't tell me how to get cog off. Timing belt is off so i want to replace crankshaft seal at the same time. nifty nev told me to use self tappers to get old seal off but how do i get to the seal...thanks guys in anticipation of your expertise in the mad land of surfdom.
                STEVIE J
                  Once the pulley is removed, the belt sprocket just pulls off the shaft. The shaft is keyed with a woodruff key in a slot so it may be stuck, in which case gentle levering against the engine with a large screwdriver or similar, around the circumfrence of the sprocket to ease it off. Maybe give it a good soaking with WD40 first.
                    Yeah, the sprocket should just pull off. A bit of levering or a gentle tap or two against the side of it with a soft hammer will help. Check the sprocket, key and keyway for any damage when removed.
                      crank cog !
                      Thanks guys, I'll give it a go..Starting to enjoy this home maintenance malarky! Might give it a squirt with wd80....twice as good as the other stuff LOL
                      STEVIE J
