How do i remove the crankshaft timing belt cog to allow me to replace the front crankshaft seal?
Timing belt crankshaft cog
On what engine????
Fill in the details in you profile.
This may help.....
http://www.toyotasurf.asn.au/techsite/
truck type
sorry guys....I got a 92 ssrx turbo diesel.........I've been on the aussie site and it dosn't tell me how to get cog off. Timing belt is off so i want to replace crankshaft seal at the same time. nifty nev told me to use self tappers to get old seal off but how do i get to the seal...thanks guys in anticipation of your expertise in the mad land of surfdom.STEVIE J
Once the pulley is removed, the belt sprocket just pulls off the shaft. The shaft is keyed with a woodruff key in a slot so it may be stuck, in which case gentle levering against the engine with a large screwdriver or similar, around the circumfrence of the sprocket to ease it off. Maybe give it a good soaking with WD40 first.Last edited by BUSHWHACKER; 11 March 2008, 15:47.
