YESSS!!
finally i had done it, i was waiting for quite some time to do this change.
first got a corner of a surf to get the reinforcement inside the skin
then got a tailgate same color from a surf that had swing away tailgate due the internal reinforcement of it
removed the old tailgate, and started to cut the reinforcement in half, due it won't fit in one piece
then when i got the old tailgate off i squeeze the bits in
before fitting in the new tailgate, needed to drill the first holes
one just behind the hinge and the first 2 for the carrier
first set of holes done and new tailgate on, the reinforcement (the 2 first halves are on)
bit of freshened up to the number plate light holder, painted in black and installed at the same time a colour reverse camera, can you see it?
testing with only 4 bolts on the carrier
and while is there, marking where the other 4 bolts goes
and finished, included debadged
