Good and bad news, Just found out my cold starting problems was down down to blown fuse. I have read a thread about unbolting the fuse box to unbolt and remove the fuse which I have done but it seems the fusebox is a completley moulded box any ideas, can I repair/bidge the fuse as a temp fix to get me to work........? Thanks.
80 amp fuse removal.
Originally posted by BUSHWHACKER View PostHi Dave, do you need a spare fuse? I have a couple here.Last edited by Webbo; 26 November 2010, 15:37.
How to get at the fuse fixings after removal of the two bolts (10mm socket)holding the fuse box to the inner wing....
Next to the Glo fuse there's a tab that needs pressing with a screwdriver to release the two fuses, they're housed in a seperate holder...
Once the tab has been pressed, the fuse holder can be pushed through and out the bottom of the fuse box...
The fuses are held in by a nut either side. Some some reason Toyota thought they would have a laugh and use two different sized nuts. (8mm and 10mm sockets needed)
