Ignition Barrel Stuck
HI, running out of ideas on this one: Truck been running brilliantly last year – really smooth. However, I had the truck sitting for a week in the garage, then started engine, pulled it out of the garage onto the drive and turned off the ignition, stopped the engine. Tried to start it again a few minutes later and the key would not turn at all in the barrel – just felt like steering lock was sticking as is common in most cars sometimes. It was cold – just above freezing. I could get the key out so I tried the original – no better. Key goes into barrel no problem but once in the barrel there no chance of it turning. I tried WD40 into the barrel.
Truck is now marooned on the drive. I pulled off the dash covers and have been trying to wiggle the key, also with varying amounts of force on the steering wheel. I have disconnected the electrical socket that feeds into the end of the lock barrel and have even tried hot wiring it just to get it back into garage – all without success (it turns over without wanting to fire – something to do with ECU I guess)
I’m at a loss of what to do. I’ve searched threads on this site and tried all the obvious solutions (brake pedal down, auto stick fully pushed into ‘P’ position), I even jacked up the front wheels to try to release any locked in torque on the steering column - all without any luck.
Next option is I guess to start really digging into the dash to try to remove the lock barrel – any idea before I start to do this?
Greg
Greg
