Spare wheel carrier/ back door swap?
  • Spare wheel carrier/ back door swap?
    I just got a new Surf with the spare wheel stored underneath rather than on the swing gate on the back door. Can I swap the back door and fit a swing gate to this Surf? I am not a fan of storing the spare underneath, especially when you need it and the lowering mechanism has rusted solid in a foot of mud in the pishing rain at -2degrees!
    You will need to reinforce the rear pillar to take the weight of the carrier but it is able to be done
      What kind of reinforcement would be needed? is any welding required, or is it a matter of fitting a plate accross the mounting bolts?
        It will probably be best to spot weld a plate to the inside but may just get away with just bolting the plate.I can't remember if there is reinforcing in the rear pillar tbh as its been a few years since i had a surf
          You had a better idea Richard.
          Sent from the iPad you "lost"
            hell thats a blast from the past slobo
              afaik you can get the reinforcing plates out of a wreck. need to cut the pillar open to get them out. i'm told you can just bolt them in.
                I thought all the body shells had the plates regardless. Worth a check first.
                Alan
                  I can't remember Al tbh but worth him looking anyway
                    http://www.hiluxsurf.co.uk/showthrea...ht=spare+wheel
                    Read this thread by Budweiser who has done the job and also the other thread by Popeye who has also done it and which is hyperlinked within Budweisers thread. Should be more than helpful.
                    Сви можемо
                      Thanks for that. I reckon that is well do-able. Off to the scrappies!
                        I got a carrier available but may cost a bit to post to you.
                          What kind of dosh do you want for it? Does it have the door metal work?
                            I will have to go look , but I am sure everything is there apart from the 2 metal reinforcers you need to weld in os D post. May have to buy some new mounting bolts for it as I had to clear out some stuff and I think they got chucked by mistake. As for cost , make an offer. Postage will be high I think.
                              Originally posted by vagrant no2 View Post
                              i will have to go look , but i am sure everything is there apart from the 2 metal reinforcers you need to weld in os d post. May have to buy some new mounting bolts for it as i had to clear out some stuff and i think they got chucked by mistake. As for cost , make an offer. Postage will be high i think.
                              £30?
