Radiator Fan Sensor Switch
  • Radiator Fan Sensor Switch
    needed for a 2.4 thanks
    anybody?
      NO ONE??
        and the connector too! that i realized its missing
          It's the same sensor in the 3.0.
          Can you use the one from your breaker?
            Where's the switch on the 3.0 Vince ? I'm pretty certain there isn't one ? (was a fair discussion a while back about the electric fan on the 3.0 only being there for air con) If there is one and I've missed it then happy days I can lose my hose adapter and get a tidier engine bay.
            Rob.
            edit - Budweiser you can buy a fan switch that will fit from any decent motor factors just give them the thread size and operating temperature.
              are you sure its a fan switch?
              afaik some versions have a low coolant switch instead of the fan switch. the fan is controlled by the ecu instead.
