set fron brake calipers for LN130
  • set fron brake calipers for LN130
    Hi all
    as title suggests after a set of front bake calipers for 2nd gen 2.4 LN130. one of my rubbe boots has gone and its pulling to the right. prob best to get a pair. after a cleanish set and no holes in the rubber drop me an email at danblako@hotmail.co.uk
    thanks
    Danny you buy new seals and pistons, an airline will pop the old pistons out easily and the rebuild is simple.
    Brian
      was thinking that but cant find the web site in england to get them from. its all from aus and costs about £200 all in!
        Alan bought them for his 3rd gen I will ask him where he got them. I am sure he was 40/50 per side.
        Brian
          http://www.brakepartssuperstore.org.uk/
          Alan
            Rebuild thread with videos.
            http://www.hiluxsurf.co.uk/showthread.php?t=76485
            Alan
              Mind Danny one £20 seal kit does two pistons so only two seal kits required.
              Strip the pistons out first you will probably only need to replace the positions that show damage on the seals.
              Brian
                thanks for that! not sure on the size of our pistons so will have to give them a call unless you can remember off hand! thanks for the rebuild thread i have taken off and split the brakes a few times as they do seize now and then but i remeber i ripped a boot in the process. they are pulling to drivers side slightly under heavy braking but have have taken off the brakes and seen the ripped boot side is fine and the drivers side one is seized and one pistion is not retracting. was just going to take the piston out give it clean and run around the rubber seal inside give it clean and pop it back. if that doesnt work will then go on to replace all seals etc.
