Wanted - Switches with working l.e.d.'s - 3rd gen ssr-g
  • Wanted - Switches with working l.e.d.'s - 3rd gen ssr-g
    Hi everyone,
    I've tried taking out switches and cleaning l.e.d.'s etc. but some have failed - I need:
    Suspension Hard/Soft switch
    Rear Mirror Switch
    Heated windscreen switch.
    All l.e.d.'s must be working please.
    Look forward to a flood of offers
    Hilux Surf SSR-G 3.0 litre auto
    You'll have better luck finding a clean Surf in Hampshire and/or Wiltshire!
    Why not replace the LEDs yourself, they only cost pennies to buy.
      Cheers 'whacker
      Any idea on part number/supplier for l.e.d. ?
      Pretty new to the scene so really enjoying finding my feet with the Surfs
        give popeye a shout as he is a l.e.d guru if Vince can't get the part numbers
          Just enter, 3mm LEDs into the search box on eBay, plenty to choose from.
          You can use the existing resistors already in the switches.
            Yep, easy to do. Two little wire legs that just need twisting around the screw in fittings...
            Even I did it....!
              You've convinced me to give it a go - got 75 led's from amazon for less than £4.00 including postage.
              Hopefully I won't knacker that many trying to fit them!
                Thanks for the push!
                Got the mini bulbs from Maplins - taken me an hour to do 5 - very chuffed!
                Thanks for the advice!
                  I remember painstakingly replacing all the bulbs with White LEDs, and scraping the green off.....
                  Only for the LEDs to fail
                  More Lift.
                  More Tyres.
                  More Engine.
