Fuel filter priming head wanted.
  • Fuel filter priming head wanted.
    My gen3 KZN 185 fuel filter head, the priming pump isn't lifting fuel up and i suspect a minor air leak is letting fuel away so the truck gets worse to start. I don't think they are fixable so looking for another one. It's the winterpack one with the tin dome with a wire coming from it and a big black button to press.
    Look on Roughtrax mate they are listed.
      Thanks for that they were the first folk I rang. They said they didn't stock them. I'll look at their website in case the lady at their end of the line misunderstood me!
        Just got off the phone to them myself & they list them for the KZN130 but not the 185... She is going to get back to me as I believe I have a similar problem!
        I've had all four glow plugs out today & tested them, refitted them back & its still slow to start from cold. Did the fuel filter as well (clean fuel inside) 3/4 filled the filter prior to screwing it back onto the head & it didnt want to prime up at all!?
          Bugger!
          I remember looking when i had the 2nd gen i didn't check for the 3rd gen i assumed if they did them for the 2nd gen they would do them for the 3rd
            I think the only difference between 2nd and 3rd gen primer head is the heated part on top . Should still work fine without the heater.
              My Gen3 doesnt have a heated top?
                Mine has the heated primer pump, but if it packs up i'll use the heated 2nd gen one with a bit of fiddling it should fit.
                  Heard back from Barry @ Roughtrax this morning. The KZN130 filter head is not the same as the KZN185. The one for the KZN185 from Toyota through Roughtrax is £127 + VAT.
                  Thankfully mine started fine this morning, so will see how it goes.
                  ATB. Will
                    Thanks for the replies chaps. I've been away a few days. Today I have tried a repair to the filter head to stop it drawing air. Removed black plunger and spring fitted a cap and seal over the hole. filled the hole with oil and screwed the seal cap to the plunger stem. used a bulb to suck fuel through the head. started better but how will it be in the morning. Watch this space!
                      Watching...
                        Well W1ll the news isn't good. when I came to start it it cranked for about 10 seconds before bursting into life and running perfectly. I don't fully understand the problem but I suspect the valves in the filterhead must be faulty and if they are not holding fuel in the right place. Maybe it runs away from the injector pump and away from the filter head back toward the fuel tank. I know when I last changed the filter it wouldn't prime and I used a squeeze bulb to lift the fuel to the filter. I'm open to ideas as I don't want to buy a new unit at over £150.
                          Hi W1LL, Don't know if you are still watching this thread still but my surf has never started better! Had a longer run the next day and I reckon any air in and around the filter head has gone now, the seal appears to be stopping more air and it's now an instant starter. Was thinking of trying the fuel bulb before the filter but am going to leave it alone now.
                            Our mechanic replaced ours with a diesel filter off a Rover 200 series. Soild filter with just an in and out on the top of it .
                              Sounds great however, how do you lift the fuel from the tank to prime the filter and the fuel pump. Is there a lift pump incorperated in your rover device?
