LN130 Engine coolant sensor - the one thats above the starter.
  • LN130 Engine coolant sensor - the one thats above the starter.
    Hi,
    I need an engine coolant sensor for a 1990 LN130 – it’s the sensor that sits just above the starter and just under the inlet manifold.
    It’s not the one that sits just under the thermostat housing.
    Cheers,
    Dom
    Originally posted by Domcr250 View Post
    Hi,
    Cheers,
    Dom
    Any good local factor should be able to get one.
    But try this https://www.simpsonsupplies.co.uk/ their part no is SI1035R
    Cost's £8.41 inc vat + £2.00 post, tel 01876510380
    the toyota part no is 89422-20010
    intermotor part no is 2-4606.
    You will need a very deep 19m/m socket or shortened ring spanner to remove/refit, and remember the alloy sealing washer behind it, this usually stick's to the block.
      This should be the one you are after
      http://www.intermotor.co.uk/?p=smpeu...je318usnbs4585 the part number is 55123
