RPM sensor/pickup needed
  • RPM sensor/pickup needed
    Hi,
    I need an rpm sensor for my injector pump.
    It's the part inside the top connected to the big round connector on top of the pump.
    It's quite easy to remove (but not so easy to refit!).
    Might consider whole pump but that's more work to remove and I only really need the sensor/pickup part.
    LN130 1991 2.4 manual, efi.
    Graham (grahamwhite@hotmail.com)
    Graham.
    1991 LN130,2.4, manual,EFI
    i have got a 2.4 manual truck here for breaking but i can't gaurentee the pump is any good as the truck wasn't running when i got it.I will strip the pump off if you want it so make an offer and i'll send the complete lot up to you to do what ever you want to it.The postage i will need to sort out seeing as your in Spain.If you can email/pm your full address i will sort out a price for sending the complete pump
      Hi,
      Could be the answer.
      The main thing is it must be EFI. I think the part I need will be common to almost any EFI pump (Denso) that surfs used.
      Could you drop me an email to the addr. below please.
      Graham.
        email sent Graham
