have you tried changing the bushes in the idler arm first if there's play in it to save you a few quid
No i havnt tried that yet, it does look like the play is coming from the arm rather than the cv joint at the end. Are the bush kits readily available ?
give them a try first then if you need another idler arm i have 2 breakers here but i'll need to check the arms first tho.Roughtrax have also put the new I/Arms on a special offer aswell at the mo
