Wanted. P/S front window motor '92 2.4
  • Wanted. P/S front window motor '92 2.4
    Bl88dy window wouldn't do up today , went down OK, then stopped. Solenoid clicks, but no movement. Taking it out to pour lots of grease into it tonight, see if it frees it up, but failing that, I'll be needing a replacement.
    Anyone got one?
    cheers all.
    andy
    There's a good chance it could be a wiring problem. The cabling that goes through the doors isn't very strong and I had a similar problem with my 2.4 (broken wire in the drivers door harness). Try temporarily reversing the wiring on the motor and see if operating the down switch then makes the window go up - that will rule out the motor.
    Roger
      ooh
      good point, will investigate
        I think I still have the front window motors if you need one.
        I'm a custard donut monster
          yes please
          Yes Please Jotto, that would be cool.
          how much you looking for?
          andy
